I want to have a status for ready to deploy and a status for deployed - is there a way to have the issues that are deployed/released daily get automatically moved to a new status lane?
Hello Melissa,
I understand that you would like to change the status of issues when the Version they belong to is released, is that correct?
Unfortunately, JIRA Software does not have this kind of automation, however, you can easily achieve it by using Automation for JIRA app.
This would be the rule:
P.S: To effectively allow the automation to execute the transition, you must configure your workflows in a way that all status can be changed to Done, properly configuring transitions from each status or flagging the option to allow all statuses to transition to Done.
Let me know if this information helps.
