Auto create multiple subtasks using Custom field value
shital chande January 30, 2020
I want to create automatically creating subtasks for taken the custom field value(int) using script runner.
What do i need to do?
Anyone suggest to me.
Nic Brough -Adaptavist-
January 30, 2020
There are a few scripts in the library you might want to have a look at (as in "copy them") - see https://library.adaptavist.com/search?page=1&products=jira&term=create
Tansu Akdeniz
January 30, 2020
Hi @shital chande ,
You should be familiar to scripting. There are lots of examples in Vendor website and community, please check this link. After finalizing your code, go to
  • Workflow -> Related transition -> Post-function -> Script Runner post-function -> custom script than paste it.
    *Btw, it is better to add as a ".groovy" file to JIRA_HOME/scripts directory and choose this file within Jira.
Following code may guide you create sub-task. You can convert according your needs.
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.bc.issue.IssueService;
import com.atlassian.jira.user.ApplicationUser;
import com.atlassian.jira.issue.IssueInputParameters
try {
Issue issue = ComponentAccessor.getIssueManager().getIssueObject(issue.key);
IssueService issueService = ComponentAccessor.getIssueService();
ApplicationUser loggedInUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
IssueInputParameters issueInputParameters = issueService.newIssueInputParameters();
issueInputParameters.setProjectId(10000L);
issueInputParameters.setIssueTypeId("10000");
issueInputParameters.setSummary(issue.getSummary());
issueInputParameters.setDescription(issue.getDescription());
IssueService.CreateValidationResult createValidationResult = issueService.validateSubTaskCreate(loggedInUser, issue.getId(), issueInputParameters);
log.error(createValidationResult.errorCollection)
if (createValidationResult.isValid()) {
IssueService.IssueResult createResult = issueService.create(loggedInUser, createValidationResult);
if (createResult.isValid()) {
log.debug("Subtask successfully created : " +createResult.getIssue().getKey());
subtaskManager.createSubTaskIssueLink(issue, createResult.getIssue(), adminUser)
} else {
log.error("createResult is not valid.");
} else {
log.error("createValidationResult is not valid.");
} catch (Exception e) {
log.debug(e);
Regards
