Auto-populate name/email in jira issue collector
Sean M December 11, 2018
Users of my application already have to login, so the application knows the user's name and email address. How do I auto-populate the name and email fields using values from my application that are displayed in the embedded jira issue collector?
Alyssa Watt
August 6, 2024
I second the solution by ICANSEEYOU7867.  Works perfectly for me and I'm a hack.
My issue collector is embedded in Confluence.  I added the function in my custom Jira script (javascript) then used the alias in the fieldValues:
<script src="your Jira issue collector source URL"></script>
<script type= "text/javascript">
function getCurrentUserName(inVar) {
var user;
var emailaddr;
jQuery.ajax({
url: "/rest/gadget/1.0/currentUser",
type: 'get',
dataType: 'json',
async: false,
success: function(data) {
user = data.username;
emailaddr = data.email;
}); if (inVar == 'username') {
return user;
} else if (inVar == 'email') {
return emailaddr;
} else {
return user;
//YOUR CUSTOM ISSUE COLLECTOR
$(document).ready(function() { window.ATL_JQ_PAGE_PROPS = $.extend(window.ATL_JQ_PAGE_PROPS, { // ==== COLLECTOR NAME ==== 'COLLECTOR ID' : { // === custom trigger function === triggerFunction : function( showCollectorDialog ) { $('#custom button').click( function(e) { e.preventDefault(); showCollectorDialog(); }); } // === default and hidden field values === , fieldValues : { // default values summary : 'some text here if you want' , description : 'some text here if you want' ,email : getCurrentUserName('email') ,fullname : getCurrentUserName('username') } }
Ojase
January 29, 2019 edited
@Sean M
Were you able to crack this? I have a similar use case. Please help
Sean M January 29, 2019
Nope. As far as I can tell, no easy way to do this.
Pavan
December 11, 2018
@Sean M While creating the issue collector the screen associated with the issue collector we can customize it, Check the project and issue types and associated screens with that. do changes to the screen then you can customize the web form. for you question create a custom fields and to screen.
Well, I was really looking for a way to set the name/email field that is built into the JIRA issue collector? I'd rather not create custom fields for name/email when those fields already exist...
dave symonds January 26, 2022
Its crock of Sh** you cant dont bother wasting your time any more
Like • damian.hyde likes this
ICANSEEYOU7867
July 28, 2022 edited
I was posting this collector onto a confluence page that uses the same authentication system.  So I know the usernames/emails are the same.  So you can get all of this info (And more!) with a little bit of extra javascript.
I tried to paste javascript code here, but this form wont let me...
https://pastebin.com/xZEJPTgM
At least with confluence, I can pull my username info using the confluence currentuser API.
I can also pull information about the confluence page from the meta content values (Such as key name, dispName, etc...) and I can use this info to automatically populate my fields.  In this case, I want to make sure I have a link, space key and article name in my collector so that we can know which confluence issue needs more info or some TLC.
As long as you can pull the username/email with javascript, this method should be doable automagically.  So theoretically this example would look like:
Like • 3 people like this
Jörn Bungartz June 20, 2023
The solution in the pastebin by ICANSEEYOU7867 works like a charm for me - thank you!
atlassian, atlassian community, loom ai, atlassian loom ai, loom, atlassian ai, record recaps of meetings, meeting recaps, loom recaps, share meeting recaps,
Loom’s guide to great meetings 📹
Register today!
