Auto-transitioning with Scriptrunner Post-Function during CREATE
Martin Hohenberg October 15, 2018 edited
I try to cause an auto-transition during the CREATE of a new ticket. The actionId for the transition is 11.
import com.atlassian.jira.bc.issue.IssueService;
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.issue.MutableIssue;
import com.atlassian.jira.issue.IssueInputParameters;
import com.atlassian.jira.issue.IssueInputParametersImpl;
import com.atlassian.jira.security.JiraAuthenticationContext;
import com.atlassian.jira.user.ApplicationUser;
import com.atlassian.jira.bc.issue.IssueService.IssueResult;
MutableIssue mutIssue = issue;
def businessdepartmentFObj = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Business department")
String businessdepartmentValue = mutIssue.getCustomFieldValue(businessdepartmentFObj).toString();
if (businessdepartmentValue == "No business impact") {
    // no business impact -> get directly into a different status
    final ComponentManager cm = ComponentManager.getInstance();
    IssueService issueService = cm.getComponentInstanceOfType(IssueService.class)
    IssueInputParameters issueInputParameters = new IssueInputParametersImpl([:])
    JiraAuthenticationContext authContext = ComponentAccessor.getJiraAuthenticationContext();
    ApplicationUser origUser = authContext.getLoggedInUser();
    IssueService.TransitionValidationResult transitionValidationResult = issueService.validateTransition(origUser, mutIssue.id, 11 as Integer, issueInputParameters);
    if (transitionValidationResult.isValid()) {
        IssueResult transitionResult = issueService.transition(origUser, transitionValidationResult);
        mutIssue.setDescription("Yay")
    } else {
        mutIssue.setDescription("Fail: " + transitionValidationResult.getErrorCollection().toString());
This code seems to succeed (green tick), but it does not actually do anything. What am I doing wrong?
Daniel Yelamos [Adaptavist]
October 16, 2018
Hi Martin Hohenberg
As Gezim suggested: why don't you use the Scriptrunner built-in post-function "Fast-track transition"?
It's built in and it does what you want it to do.
Check the documentation for it here
Do tell me if I can help you further.
Cheers!
DYelamos
Gezim Shehu [Communardo]
I usually use the "old" method to transition, by calling the workflowTransitionUtil
WorkflowTransitionUtil workflowTransitionUtil = (WorkflowTransitionUtil) JiraUtils.loadComponent(WorkflowTransitionUtilImpl.class);
workflowTransitionUtil.setIssue(mutableParentIssue);
workflowTransitionUtil.setUserkey('userkey');
workflowTransitionUtil.setAction(actionID);
workflowTransitionUtil.validate();
workflowTransitionUtil.progress();
However, in your case, I would suggest to simply use the built-in post function
"Fast Track Transition Issue". Much more convenient and you just need to specify the condition and action ID.
Let me know
Learn more
