Auto update end date with linked issues in separate projects
carlos sarrate November 29, 2023 edited
Project A can have one or multiple Project B linked issues. I'm trying to set up an automation that will auto-update the end date on Project A based on the furthest end date of all the Project B linked issues. I'm guessing this would be triggered any time the end date in Project B linked issue is updated.
Any help would be greatly appreciated!
November 29, 2023
Hi @carlos sarrate
Do you already have a rule started?
If so, please post images of your complete rule, the actions / conditions / branches details, and of the audit log showing the rule execution.  Those will provide context for the community to offer suggestions.
If you have not started a rule yet, have you tried doing this with a global (or multiple-project) scope rule, and the lookup issues action with JQL?  That would allow gathering the relevant issues, and then using the max function on the date field, such as with this:
{{lookupIssues.duedate.max}}
carlos sarrate December 10, 2023
Hey @Bill Sheboy
Sorry got tied up with another automation, working on this one again. No, I don't have anything set up yet as I'm still just trying to get my head around the flow.
I did realize I could simplify it to... When Project B ticket has the "Due Date" updated or is linked to Project A trigger Project A to update "Due Date" only if it's earlier than Project Bs "Due Date"
I did find Date compare {{[date1].compareTo([date2])}} but im not sure i how i would implement it.
Thanks for the help,
Carlos
December 11, 2023
I recommend trying to create your rule; that will help work out the details.
To get you started on creating your rule, please refer to these documentation and example sources:
One challenge with your scenario is in the details as issue links are not a 1-1 or 1-many relationship: they are many-to-many.  So how do you know to which issue to check?
If we assume the links are such that there is only zero-or-one issue linked in project A, this might be done with a global / multiple-project scope automation rule.  An outline of the rule could be this, assuming Jira Cloud is used:
  • trigger: due date updated
  • condition: project is B
  • action: lookup issues, with JQL to find any linked issues in Project A meeting your criteria
  • advanced compare condition: to check if there was one-and-only-one issue found, by comparing {{lookupIssues.size|0}} to 1
  • action: create variable, to save the key of the Project A issue, with {{lookupIssues.first.key}}
  • action: lookup issues again, this time with JQL to find the matching Project B issues which are linked to the one found in Project A
  • advanced compare condition: to check if there were any issues found, by comparing {{lookupIssues.size|0}} to greater than 0
  • branch: on JQL to the Project A issue
    • action: edit the issue, with the maximum date value
carlos sarrate December 11, 2023
Thank you so much for this! This is going to be a huge help, I'll let you know how this turns out.
Like • Bill Sheboy likes this
