Hi all,
i am wondering if you can help me. I have an insight object schema called Servers.
Under Servers I have about 700 systems that I would like to automate patch changes for on a weekly / monthly basis. I would like to group these changes based on the following fields:
Business Unit
Patch Day
Patch Time
As an example:
SERVER A is assigned to Business Unit 1 with a patch day of Tuesday and a Patch Time of 8AM - 11:59PM (8AM - 11:59PM is a string value)
SERVER B is assigned to Business Unit 2 with a patch day of Thursday and a Patch Time of 8PM - 10PM (8AM - 10PM is a string value)
i am not sure how I can get this working. I am busy doing the following with powershell but not sure if is optimal:
1) Call the JIRA insight api and return all business units from the Business Unit Schema
2) Do a for each loop with results from business unit and do another API call to patch day schema
3) Do a for each loop on patch day schema and do yet another call to API call to Patch Time schema
4) Do another for each loop on Patch Time and build a iql query that would search objectType =“Servers” AND Status = “Active” AND “Business Unit” = “$($bu)” AND “Patch Day” = “$(“$patchDay”) AND “Patch Time” = “$(“$patchTime”)
5) from there I do yet another call to the JIRA API doing to IQL search. That is about how far I am, but it really does not seem optimal.
once I get the results from the last query I am working on building to json I need to push to JIRA to get it to create the change control. Is this the correct approach? The servers do need to be linked to a custom field that is associated with the Change Control type.
hope that all makes sense.
