Is there a way for an issue to automatically be assigned to a specific Component at creation? Can it be based on the Epic Link?
Dave
Hi @Dave Frohwitter ,
This is not possible with out of the box JIRA. It is possible to set a fixed Component, but not one that follows a condition!
The only way to do this would be to use a plugin like Scriptrunner and create a script listener.
Here is an example :
https://community.atlassian.com/t5/Jira-questions/set-Component-in-groovy-script/qaq-p/196655
import com.atlassian.jira.ComponentManager import com.atlassian.jira.issue.CustomFieldManager import com.atlassian.jira.issue.Issue import com.atlassian.jira.issue.MutableIssue import com.atlassian.jira.issue.comments.CommentManager import com.atlassian.jira.issue.fields.CustomField import com.atlassian.jira.util.ImportUtils import com.atlassian.jira.user.util.DefaultUserManager import com.atlassian.crowd.embedded.api.User import com.atlassian.jira.project.Project MutableIssue issue = issue Project project = issue.getProjectObject() def component = componentManager.getProjectComponentManager().findByComponentName(project.getId(),'ComponentName') issue.setComponentObjects([component])
Hope this helps, let me know if you decide to proceed with this solution and need further help with the script.
JT
