Automatic due date by issue type when creating ticket.
rozuan July 29, 2013
I need a way to do automatic due date by issue type when creating a ticket. For example, I have an issue type which need to resolve within 3hours. How to set this?
Thank you.
Tsol
July 29, 2013
Have a look here. Check Henning's answer.
Danison Rarama November 9, 2018
Trying to Automatically assign a due date to all created ticket excluding weeks.
I tried this script but giving me an error for the first 3 lines
unable to resolve class com.atlassian.jira.component.componentaccessor
Im using Script runner cloud and just want to make sure all created tickets are automatically set for 5 days not including weekends.
import com.atlassian.jira.ComponentManager
import java.sql.Timestamp;
def cfTimeline = customFieldManager.getCustomFieldObjectByName("Due Date")
def cfTimelineValue = issue.getCustomFieldValue(cfTimeline).toString()
// Days in the future when the issue is due.
int DueInDays = 5
log.warn ("ASZ Timeline Value: "+ cfTimelineValue )
MutableIssue myIssue = issue;
// Set the number of days.
switch (cfTimelineValue) {
case "1 - Immediately": DueInDays = 1; break;
case "2 - Today": DueInDays = 2; break;
case "3 - Business Week": DueInDays = 5; break;
case "4 - 30 Days": DueInDays = 30; break;
default: DueInDays = 5; break;
// Make sure the due date doesn't fall on a weekend.
Date today = new Date();
Calendar MyDueDate = Calendar.getInstance();
MyDueDate.add(Calendar.DATE,DueInDays)
while ([Calendar.SATURDAY, Calendar.SUNDAY].contains(MyDueDate.get(Calendar.DAY_OF_WEEK))) {
MyDueDate.add(Calendar.DATE,1)
Casey Maynard
Could someone add some direction as to how I can get my Due Date (or even a custom Due Date field) to Auto-populate from the Release Date value assigned to the Fix Version?
Warren McInnes
February 9, 2014
Hi, Yes this code does work correctly.
How ever is there any way to exclude weekends? Or for instance if the due date falls on a weekend that it gets changed to the very next monday?
Thanks in advance
Kevin Dalton
Would be curious if there is a way to exclude weekends or if it is on a weekend to push it till monday.
A November 4, 2015
any luck in identifying that??
Warren McInnes
November 4, 2015
I think JIRA handles this automatically? I haven't looked into this for quite sometime.
A November 5, 2015
Hi Warren, Below is my code. Currently not working with working days def dateField = getCustomFieldValue("customfield_11111") def numberField = getCustomFieldValue("customfield_11234") def number = numberField?.intValue() if (!number || !dateField) return def result = dateField + number return new Date(result.getTime())
A November 5, 2015
i am adding the duration and calculating the end date, but end date is added to date. not to calender days
Warren McInnes
November 5, 2015
Is end date a custom field? or are you trying to populate the due date?
A November 5, 2015
yes its a customfield i am trying to add start date with duration and out put to be displayed on scripted field. So far only reached till adding date with duration, but it is considering sunday and saturday also. my duration is purely calender days
rozuan August 13, 2013
Thanks all. I have found the way in atlassian answer also and I do this by using Script Runner.
And the script as below:
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.customfields.CustomFieldType
Calendar cal = Calendar.getInstance();
// set due date to: current date + 8 days
Timestamp mydueDate = new Timestamp(cal.getTimeInMillis()+ 8*1000*24*60*60);
myIssue.setDueDate(mydueDate);
T I
July 29, 2013
