×Using Excel power query i'm able to automatically download the queries into excel and perform change in values.
I would like to have an automation (Either you call it as integration / API) where issues updated with new values in excel to get updated in Jira whenever user triggers for action.
Hello Satheesh,
How are you?
I understand that you would like to be able to reflect the changes performed on a CSV file directly in the JIRA issues, keeping both excel and JIRA synced on each update. Is that correct?
You can use the following add-on to achieve this kind of functionality:
Using this plugin create, you will be able to modify and transition issues right from MS Excel.
Let us know if this is the option you are looking for.
In advance, Have a nice weekend! :)
Dear Petter,
Can you share the process to reflect the updates made in excel to JIRA
is there a button or some action required to sync
I am facing below error, pls help:
InsertDeleteConflict. Please try again
Hi @Petter Gonçalves ,
Hope you are doing well!
Do we have this available for cloud?
Regards
Rahul Jith
