Automatic workflow transition not visible (need refresh screen)
Franck LAMBEZ April 1, 2016
I try to automatically perform a workflow transition (depending on a customfield value) and it works!
BUT when my ticket is shown, the transition is not visible.
When the F5 refresh key is pressed everything is displayed all right.
JIRA knows which is the state, but the transition is not shown.
I perform those publication functions (sorry, it's in french language):
  1. Crée la demande d'origine.
  2. Paramétrez l'état de la demande sur l'état lié de l'étape de flux de travaux de destination.
  3. Déclenchez un événement Demande créée qui peut être traité par les écouteurs.
  4. Script workflow function : Fast-track transition an issue : If the condition is met the action 781 Enregistrer Brouillon will be applied.
    Note that this should go after the Fire Event function.
JIRA does not allow me to create new publication generic functions (like reindex) AFTER the 5th step.
Thank you for your help.
Franck
MarcelW
I too have been noticing this.  I'm using JMWE post-conditions to transition parent issue when moving a sub-task.
Fidel Castro
April 5, 2016
Hi Franck,
Which plugin are you using to perform automatic transitions?
