Automatically Create Issue on Sprint Start and add to current Sprint
Omar Rashid November 1, 2018
Is it possible through scripting somehow to have an issue automatically created and added to a sprint when the user has started the sprint, through scripting? Thanks for any feedback you guys can offer!
Hadas Hamerovv
August 29, 2021 edited
Ok. Here is how we managed to do that:
1. Create a script listener and set the triggering event for a 'sprint start'
2. In the Script Context console write the following:
NOTE - Replace the following strings to your own ones:
'your-project-key' - to your project key name
'IssueType' - to the issue type you are trying to add (i.e Bug, Feature, Task etc.)
summary and description - write whatever you want. In our case we added the sprint name to the issue name thus you see the @$sprintName
Hope This helps
def projectKey = 'your-project-key'
def projectId = get("/rest/api/2/project/${projectKey}").asObject(Map).body.id
def taskType = get("/rest/api/2/issuetype/project?projectId=${projectId}").asObject(List).body.find { it['name'] == 'IssueType' }['id']
def sprintName = sprint.name
post("/rest/api/2/issue")
.header("Content-Type", "application/json")
.body(
fields: [
summary : "$sprintName - task-name",
description: "Commit all the subtasks which are done in $sprintName (Bug fixes and New Features) to Staging",
project : [
issuetype : [
.asString()
Hadas Hamerovv
Wow, I have the same problem and can't figure out how to code this. I am reading all the ScriptRunner tuts and still am confused. Will let you know if I manage to do that
