I'm looking for a way to create filters for a project automatically.
When I create a project there are several filters that I want to create by default for each project. Is there a simple way to do it ?
Where is the saved filters information kept ?
The only useful data I found was here:
https://developer.atlassian.com/display/JIRADEV/How+to+create+a+custom+preset+filter
But I'm looking for another way.
Alon
Don't directly manipulate the database. Do a simple script that uses curl and post JSON requests to JIRA
Docs at - http://docs.atlassian.com/jira/REST/latest/#id325922
But adding pre-set filters are best (using a plugin), since it won't clutter your instance with so many filters being listed.
