Is there an easy way of setting the Estimated Time Remaining field in Jira to zero when the issue is resolved or closed?
Paul
In the workflow add a post function - Update issue field. Select Remaining estimate and hit update and publish the workflow
Log Work Utilities add-on does this without a need to modify every workflow manually: https://marketplace.atlassian.com/plugins/com.gebsun.plugins.jira.log-work-utilities/server/overview
