Automation: Create Task can't change assignee
Andreas Lorz
February 16, 2024 edited
Hi, I'm new in automation and my first automation doesn't work as I would expect.
As Trigger I have a manuel trigger. A button that can be clicked by everyone. And then an Action for creating an issue. In this case its a Sub-Task Issue and I want to assign this issue to the user who triggered the event. The user wo pressed the automation button in an issue.
But everything I tried, everytime the issue is assigned to the Actor of the automation rule.
What am I missing? Thanks in Advance
What I find strange is that if you look in history of the created issue you can see that it was created correctly but is changed immediately after that to another value.
3 votes
Andreas Lorz
Ok, problem was the workflow. There was a Postfunction in the create Transition, where assignee is set.
Arun Unnikrishnan
February 16, 2024
Hi @Andreas Lorz ,
I could achieve the same using the below automation. The only change I did was 'Project: Same project as trigger'
SERVER
VERSION
9.12.2
Register today
