Sign up Log in
Automation: Getting JQL error
Gisela Lassahn
Hi everybody,
I'm using Automation in Jira Data Center with rule triggered by "Issue linked".
I've created an If-block with the following JQL:
{{issue.project}} not in (STCS, ITGOV) or {{issue.issuetype}} != Epic or {{destinationIssue.project}} not in (STCS, ITGOV) or {{destinationIssue.issuetype}} != Epic or {{destinationIssue.project}} = {{issue.project}}
I'm getting an JQL error saying:
Fehler in der JQL-Abfrage: Das Zeichen "{" ist ein reserviertes JQL-Zeichen. Sie müssen es stattdessen in eine Zeichenfolge einfügen oder das Escapezeichen "\u007b" verwenden. (Zeile 1, Zeichen 41)
Translated in English:
JQL query error: The "{" character is a reserved JQL character. You'll need to put it in a string instead, or use the "{" escape. (line 1, character 41)
What am I doing wrong and how should my JQL look like?
Many thanks for your help and best regards,
Gisela Lassahn
May 3, 2024
Hi @Gisela Lassahn
If I understand your question, the JQL statement you show is not valid.
JQL statements have this syntax: some_issue_field OPERATOR some_value
For example: project IN (ABC, DEF)
Instead you are trying this: some_value OPERATOR some_other_value
For example: ABC IN (DEF)
And so there are no issue fields referenced, leading to the syntax errors.  (JQL is not a SQL, and so does not support those types of logical / comparison operations of data.)
Without knowing the specifics of the problem you are trying to solve, I believe you could either use Issue Conditions or Advanced Compare Conditions, testing the smart values with logical operators.
John Funk
May 3, 2024
Hi Gisela,
Try using just:
issuetype != Epic
it’s just JQL so you shouldn’t need the smart value there.
Gisela Lassahn
Hi @John Funk ,
I could do this for the trigger issue, but not for the destination issue, or am I wrong?
John Funk
May 3, 2024
Correct. But the error is for character 41, which is before that.
Manoj Gangwar
May 3, 2024
Hi @Gisela Lassahn
Could you please try the below JQL and check?
{{issue.project}} not in ("STCS", "ITGOV") or {{issue.issuetype}} != "Epic" or {{destinationIssue.project}} not in ("STCS", "ITGOV") or {{destinationIssue.issuetype}} != "Epic" or {{destinationIssue.project}} = "{{issue.project}}"
Gisela Lassahn
Hi @Manoj Gangwar ,
I've tried your JQL but I'm still getting exactly the same error message.
In the message details I can see that my JQL is resolved to:
(key IN (ITGOV-66) AND (SmartProjectBean{source=Project{self='https://jira....
The "{" after "SmartProjectBean" is on position 41 and seems to cause the problem.
Gisela Lassahn
@Manoj Gangwar ,
I've found workaround.
No I have two Smart Value Variables:
  • ProjectShortcut, defined as: {{issue.key.substringBefore("-")}}
  • DestinationProjectShortcut, defined as: {{destinationIssue.key.substringBefore("-")}}
Now I can work with these variables.
Many thanks to you for your time!
Gisela Lassahn
@Manoj Gangwar :
Now I've got another problem.
My JQL now is:
"{{ProjectShortcut}}" not in ("STCS", "ITGOV") or "{{issue.issuetype.name}}" != "Epic" or "{{DestinationProjectShortcut}}" not in ("STCS", "ITGOV") or "{{destinationIssue.issuetype.name}}" != "Epic" or "{{DestinationProjectShortcut}}" = "{{ProjectShortcut}}"
The error message is:
... error running JQL: "(key IN (ITGOV-66) AND ("ITGOV" not in ("STCS", "ITGOV") or "Epic" != "Epic" or "UTK" not in ("STCS", "ITGOV") or "Story" != "Epic" or "UTK" = "ITGOV"))" - Feld 'ITGOV' existiert nicht., Feld 'Epic' existiert nicht., Feld 'UTK' existiert nicht., Feld 'Story' existiert nicht.
In English:
Field 'ITGOV' does not exist., Field 'Epic' does not exist., Field 'UTK' does not exist., Field 'Story' does not exist
Gisela Lassahn
As I cannot create combinations of Issue Field Conditions connected with "OR" in an If-block (only with "AND"), I'm using an If-else-structure with else-if branches and Issue Field Conditions now and do the things in the else-branch instead of the if-branch.
SERVER
