I'm trying to run an automation that sets a custom user picker field to users in a project role.
I initially looked at using the smart value {{project.role["Approver 1"].members}} in the selection field in the "Edit Issue" component, but that doesn't return anything.
I've looked at a couple other posts that make a ton of sense to me at the moment:
If someone could either point me in the right direction to know where to edit what condition, use the proper smart value, or anything else, I would appreciate it.
I am using Jira Data Center in a Software type project.
Hi @Taylor Chappell,
Both posts you give links to are for Jira Cloud. In Jira DC, you can only get the project role members by sending a web request in Automation.
Check out this guide Automation For Jira - How to create a rule that adds to the watcher list of an issue the members of a project role. I tried setting up a test rule on my instance using this guide and was able to get members of my project role. So it should work for you too.
My rule as a reference:
The smart value {{webhookResponse.body.actors.name}} returns usernames of role members.
