Sign up Log in
Automation for Jira rule will not enable
Lee Cash
I've written a new rule (if it matters it uses regex to check the summary text of a Jira) but if it's enabled it won't save (spinning wheel) and when I disable it, while it will save my changes, I can't enable it from the dashboard.
I click on the green button, it flashes on for a second, and then goes back to disabled. I have no idea why this is happening but it's incredibly frustrating.
Lee
Lee Cash
January 25, 2021 edited
Answering my own question here but this is more for posterity and for any other people who may encounter this issue. I would also love to hear from the developers of the app to confirm my theory! :)
I started to rebuild the rule from scratch (as it was working at one point) and it turns out that when I added a third if/else regex check, the problem occurred. Maybe my rule became too complex and ran out of memory? My regex may also have been grossly inefficient and could have hit a timeout of some sort. I'm not sure. I've asked my JaaS admin to provide me with logs to see if anything turns up.
I fixed it by changing ^(?!MyText).+ to ^((?!MyText).)*$
Both expressions look for the absence of a certain string of text at the start of the summary text. The former version, however, is problematic when added multiple times in an if/then else statement.
Hope this helps someone!
Lee
stefan_wilke December 19, 2021
Doing a rule to copy a template tree I encountered same problem , with the green button not enabling the rule.
After some time the editor protested on that the summary field was empty, not sure how I managed to publish a rule with an empty summary field.
Did copy paste of {{destinationissue.summary}}, and will do that again but make sure to press enter before save.
Could enable after that.
Register Now
Upcoming Jira Events
