I created an automation rule where when a field is has a value it will trigger creation of a task. That field means that the task needs to be created. The problem is every time the field is edited it creates another task. Once the task is created I want it to stop executing. I'd appreciate a little help. Thank you.
@Nathaniel Herron post this script here to us analize
I'm using the project automation wizard so I don't really have a script but it's really short
When value changes for Text2
Then: Create new Task in same project
Is there a filter I can apply or a better trigger so it says: when value is created in Text2? or When value is Changed it Text2 for the first time?
You would have a list of trigger options at least? If yes, post here
both
I used trigger when "field value changes" in field Text2
available are
issue commented
issue created
issue transitioned
incoming webhook
issue assigned
issue deleted
issue link deleted
issue linked
issue moved
issue property updated
issue updated
manual trigger
multiple issue events
scheduled
sprint completed
version created
work logged
