Hello community,
How could I create an automation rule where the trigger is based on which is the name of a previously created issue.
In other words, I want to execute a rule only when a specific story (XX) is created so I can include some sub-tasks under it. This story is created weekly, so I need this rule to be executed each time a story with name XX is created.
Any help will be highly appreciated!
I recommend trying the Issue Created trigger, following that immediately with a condition test on the summary. The rule will trigger more often but it will not continue processing if it does not match your condition.
Hi @Bill Sheboy ,
Indeed! I have used that trigger and it works by including an 'If" based on summary field.
I still have one additional query maybe you could help me with.
As an story is being created every week under an already existing epic, after some months I will end up with 20 stories named the same way. Would be possible to include in the rule anything that adds a prefix (or something similar) so I can differentiate one weekly issue from the previous one. So then if the story is called "Weekly analysis" I will end up with something like:
W1 Weekly analysis
W2 Weekly analysis
W3 Weekly analysis
W4 Weekly analysis
Let me know if there is a way of having something like that in Jira.
Thanks in advance!
Alvaro
Yes, that is possible using the format() function for date fields. Please look here to learn more about that:
https://confluence.atlassian.com/automation/jira-smart-values-date-and-time-993924864.html
Hi @Bill Sheboy ,
But can this be applied in the Summary field of an issue created with an scheduled trigger?
I have the feeling we are talking about different things. I could use the current date to specify the week of the year (or week inside a month), so this will differentiate each story from the others. But how could I include that "differentiator" in the summary field of each story with my automation rule?
Thanks in advance for your help!!
I do not believe you can do that in the scheduled trigger's JQL; specifically, I do not believe that JQL can be dynamic.
Instead I was suggesting to allow the rule to fire more often than needed and then use an advanced compare condition to limit what gets processed, such as by your timeframe/week information in the issue summary.
I guess that I should use some kind of JQL query to detect that specifi story, but I currently struggle to write it properly.
