Automation to cascade field value from children to parent tickets
Vasanta Kumaar
Hi Team,
We like to know if there is a way in Jira to read from the “child” issue tickets (ie: User Story) linked to a Parent one (ie: Epic) and cascade/copy the info to same custom field present in Epic issue type.
Vasantakumaar
2 accepted
Mohanraj Thangamuthu
June 18, 2024
Duc Thang TRAN
June 18, 2024
Hello @Vasanta Kumaar
For child value of cascade : {{issue.fields.customfield_xxx.child.value}}
If you want copy to Epic , you can try something like that
"update": {
"customfield_xxx": [
"set": {
"value": "{{triggerIssue.fields.customfield_xxx.value}}",
"child": {
"value": "{{triggerIssue.fields.customfield_xxx.child.value}}
Vasanta Kumaar
Hi @Duc Thang TRAN
Thanks for the above JSON values. I have tried and got below error:
 (data was not an array (customfield_XXXXX))
Please let me know what might be the issue.
Vasantakumaar
Vasanta Kumaar
Hi @Mohanraj Thangamuthu  & @Duc Thang TRAN ,
Thanks for the answer, will check and update.
I have another issue, what? If another child problem is added to the parent ticket, and automation runs, the existing value of the custom field will be cleared and replaced with the new one. How to avoid.
Vasantakumaar
Duc Thang TRAN
June 19, 2024
In this case, I suggest adding if else conditions to  modify the value of parent field  cascade  if the parent's cascading field is empty or other condition
