Sign up Log in
Automation to create multiple linked issues
Natalie Al-Delemi January 15, 2024
I'm trying to create an automation to create linked issues from an assets custom fields with multiple objects.
I tried to use smart values and for each branching but it only creates one issue from the list.
January 15, 2024
Hi @Natalie Al-Delemi
Your rule shows branching to the current issue, and not branching over the objects (or smart values).  And so it would only create one new issue.
I am not using Jira Server, and so I cannot check this, but I do not believe Jira Server automation supports branching over anything except issues.  Please check that to confirm.
Natalie Al-Delemi January 17, 2024
Hi Bill,
thanks for your quick response. It's true that data center doesn't have the advanced branching functionality available.
What option do I have to create an automation?
January 17, 2024
I do not believe that would be possible with the built-in rule features, and the suggestion to add advanced branching for Server / Data Center has not had much activity: https://jira.atlassian.com/browse/JIRAAUTOSERVER-749
Other things to try would be:
  • investigate marketplace addons for this capability
  • build a service with another language / platform and then call that from an automation rule
