Back up single project
prasad July 2, 2015
How to take back up of a single project in JIRA and restore only that project in a test instance with out disturbing test environment.
Nic Brough -Adaptavist-
July 2, 2015
You can't.  You can export everything to xml and then import a single project from that (although it's still going to "disturb" the test system)
prasad July 2, 2015
Thanks Nic brough for response.Can you tell me what is the better way to do this with minimal rework
July 2, 2015
Export everything to xml and import the single project you need...
Paulo Hennig
July 2, 2015
In additional to Benito and Nic responses, we have this open suggestion request: https://jira.atlassian.com/browse/JRA-34307
Benito Picarelli
July 2, 2015
Hi there,
As previously mentioned, there's no way to export a single project. Here are the documentation for backing up your system and importing a single project:
Backing up data
Restoring a Project from Backup
Please note that if the instance that you are importing the project into doesn't have the same workflows, fields, configurations, as the former project, you'll need to configure that too beforehand.
