Backups - Necessary License Keys
Karrie Dash
I will be doing a Cloud -> Temp Server and a Live Server -> Temp Server (this is just a test scenario) full system backup. What license keys will I need to save before completing any full system backups?
Nic Brough -Adaptavist-
April 18, 2017
None.
You will need a production licence for the target restoration system, and I'd recommend a developer licence for the temp server.  But there's nothing to save on Cloud, the licence there only applies to the Cloud system and is dropped on export.
Karrie Dash
Thanks. If I export a backup from Jira Live and will be importing it to Jira Temp, should I put Jira Temp's license key in the License box so it overrides Jira Live's licenses in the backup file so one license is not located on two instances?
