We have a SVN repo that has a precommit hook to force a message on commits.
When we are setting up the VCS tagging task, we get errors because the Bamboo task doesnt supply a message. The error message is below.
Is there a way to have bamboo add the message? What is the recommend solution in this scenario.
com.atlassian.bamboo.task.TaskException: Exception when tagging repository at com.atlassian.bamboo.plugins.vcs.task.VcsTaggingTask.execute(VcsTaggingTask.java:57) at com.atlassian.bamboo.task.TaskExecutorImpl.executeTasks(TaskExecutorImpl.java:183) at com.atlassian.bamboo.task.TaskExecutorImpl.execute(TaskExecutorImpl.java:91) at com.atlassian.bamboo.build.pipeline.tasks.ExecuteBuildTask.call(ExecuteBuildTask.java:84) at com.atlassian.bamboo.v2.build.agent.DefaultBuildAgent.build(DefaultBuildAgent.java:204) at com.atlassian.bamboo.v2.build.agent.BuildAgentControllerImpl.waitAndPerformBuild(BuildAgentControllerImpl.java:103) at com.atlassian.bamboo.v2.build.agent.DefaultBuildAgent$1.run(DefaultBuildAgent.java:109) at com.atlassian.bamboo.build.pipeline.concurrent.NamedThreadFactory$2.run(NamedThreadFactory.java:50) at java.lang.Thread.run(Unknown Source) Caused by: com.atlassian.bamboo.repository.RepositoryException: Error while creating tag at com.atlassian.bamboo.repository.svn.SvnRepository.createTag(SvnRepository.java:1793) at com.atlassian.bamboo.plugins.vcs.task.VcsTaggingTask.execute(VcsTaggingTask.java:52) ... 8 more Caused by: org.tmatesoft.svn.core.SVNException: svn: Commit failed (details follow): svn: Commit blocked by pre-commit hook (exit code 1) with output: ***************************************************************************** Your commit has been blocked because you didn't give any log message Please write a log message describing the purpose of your changes. Important: Please add the issue identifier (ie, PS-15, OPS-15) in upper case then try committing again. -- Thank you, Onlife Health Configuration Management Team ***************************************************************************** at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:64) at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:51) at org.tmatesoft.svn.core.internal.wc.SVNCopyDriver.copyReposToRepos(SVNCopyDriver.java:380) at org.tmatesoft.svn.core.internal.wc.SVNCopyDriver.setupCopy(SVNCopyDriver.java:629) at org.tmatesoft.svn.core.wc.SVNCopyClient.doCopy(SVNCopyClient.java:426) at com.atlassian.bamboo.repository.svn.SvnRepository.copyRepository(SvnRepository.java:1751) at com.atlassian.bamboo.repository.svn.SvnRepository.createTag(SvnRepository.java:1789) ... 9 more
Please add the below code and skip all validations if the build is from bamboo. It worked for me.
AUTHOR=`$SVNLOOK author "$REPOS"`
if [ "$AUTHOR" = "xxxxxxxxxx" ]; then
exit 0
fi
Hi Guys,
There is actually an improvement request to make the VCS tagging more configurable with the commit message. You can watch the request at https://jira.atlassian.com/browse/BAM-10658
Sure, pass a message with the commit.
Not knowing exactly how your subversion commit is being created (are you using a plugin or just tagging from the command line) you can add a -m "my checkin message to satisfy the Onlife Health Configuration Management Team"
as an argument to whatever command you are using to generate the commit action.
I do most of my svn activity using scripts but I suspect you can add the -m "your message here" string on the argument line of whatever subversion action you're committing. (tagging, branching, etc.)
Hi got the same problem, but the -m does not work for me
I am using the VCS Branching plugin with SubVersion as repository
and in the Display Name field I've added: AppName_1.1.x -m "Branch created by Bamboo"
but it failds with error:
14-Mar-2013 08:05:31 Caused by: org.tmatesoft.svn.core.SVNException: svn: Commit failed (details follow): 14-Mar-2013 08:05:31 svn: Commit blocked by WANdisco pre-replication pre-commit trigger (exit code 1) with error: Please enter a commit message which details what has changed during this commit. 14-Mar-2013 08:05:31 svn: MERGE of '/repos/test/BambooTest/branches': 409 Conflict (http://svnglobal.xxx.xxxxx.com)
anyone?
