Hello guys,
I do not understand why this jql request doesn't work :
status was not "Some_Status" before updated
I got this error message : "Date value 'updated' for predicate 'before' is invalid. Valid formats include: 'yyyy/MM/dd HH:mm', 'yyyy-MM-dd HH:mm', 'yyyy/MM/dd', 'yyyy-MM-dd', or a period format e.g. '-5d', '4w 2d'"
Updated is not a date?
any suggestions?
Dear Julien, hi!
In JQL after before it is possible to use fixed dates or specified date functions.
See more information here: https://confluence.atlassian.com/jirasoftwarecloud/advanced-searching-fields-reference-764478339.html
Ok but not the updated field as mentioned here https://confluence.atlassian.com/jiracorecloud/advanced-searching-fields-reference-765593716.html#Advancedsearching-fieldsreference-UpdatedUpdatedDateupdatedDateUpdated
This is the documentation for Jiracloud, but I think it's the same behaviour for jira server.
Thanks for the response.
I do not understand why you would want to check on the 'before updated' ?
Won't "Status was not 'some_status'" get you the result you are looking for?
Hello Fazila,
We got the Riada Notifications Assistant email sender plugin.
With this plugin, I have a notification triggered by the "updated event" of a transition.
In this notification triggered, I want to get the list of issues that WASN'T in the a special status before the last update by a JQL query.
I must admit that is not clean, but I'm still figuring out how to manage this notification.
