Behavior does not actually add the value to the issue, it just selects it
Cristina_Abunei
January 9, 2018
I have the following behavior which refers to two custom fields (both are select lists). I want it to set a value to custom field b when something from A is selected:
def reqproj = getFieldByName("Requesting Project")
def segment = getFieldByName("Segment")
def reqprojVal = reqproj.getValue()
// If Select List 1 is set to option A then set selectList2 to option B
if(reqprojVal.toString().contains("A88")){
// Set the value to the ID of option B
segment.setFormValue(26744)
else if (reqprojVal.toString().contains("B")) { segment.setFormValue(26744)}
else if (reqprojVal.toString().contains("C")) { segment.setFormValue(26745)}
Although it does not throw an error, it seems that it only selects the value on an issue, but not also actually adds it. To be more clear: if I open an issue, on the view screen I do not see the value for Segment, but if I edit the issue, I see that the proper option is selected.
Please help.
Thank you.
Cristina_Abunei
January 9, 2018
Disregard the question, I applied the behavior to the second custom field instead of the first one.
Register Now
