×After updating jira .8.3.2
Behaviors plug in is not editable.
( cannot delete, edit, add or map anything in behaviors plug in )
any resolutions ? throws an errror as " NOT SECURE"
Hello @siva
Thank you for reaching out.
Could you please provide us what is the exact error returned for you in your JIRA logs once you upgraded your JIRA? Also, is there any error returned in your browser javascript console?
Considering the information you provided, I recommend you to check if your Scriptrunner plugin is also compatible with your new JIRA version and, if it is not, try to upgrade it too:
Also, try to disable and enable back the plugin. Sometimes, the authentication between both applications can be lost in during JIRA upgrade and must be established again.
Let us know if this information helps.
