  • Community
  • Q&A
  • Jira
  • Questions
  • Behaviour plugin: Show/Hide customfield in Create screen depending on the value of a cascading select list
Begoña Bonet
In creation screen I need to show or hide a customfield depending on the value selected by user in a cascading select list.
I've included this script but it doesn't works:
if(getActionName() == "Create" && getFieldByName("Área/Subárea").getValue()=="Proyectos,Proyectos menores"){
      getFieldByName("Es menor").setHidden(true);
if(getActionName() == "Create" && getFieldByName("Área/Subárea").getValue()!="Proyectos,Proyectos menores"){
      getFieldByName("Es menor").setHidden(false);
What am I doing wrong?
Thanks in advance
Thanos Batagiannis [Adaptavist]
November 27, 2015
Hi Begona,
The cascading list value is an ArrayList with Options, therefore the .getValue() returns to you an ArrayList with the Option ids (as Strings). Below is an example of how to get the id and then through the optionManager to get the value for this id.
def optionManager = ComponentAccessor.getOptionsManager()
def optionMap = getFieldByName("Área/Subárea").getValue()
//this will give you the option id for the your first (parent) choice
def parentOptionId = optionMap?.getAt(0)
if(!parentOptionId)
 return
//this will give you the option id for the child choice
def childOptionId = optionMap?.getAt(1)
if(!childOptionId)
 return
// cast String to Long
def longValue = Long.valueOf(childOptionId).longValue()
// get the Option with the particular id
def option = optionManager.findByOptionId(longValue)
def optionValue = option.getValue()
//Now you have a String value for the parent Option that you can use in your equality checks
if(getActionName() == "Create" && optionValue=="Proyectos"){
Please let me know if you need further assistance
Kind regards
Thanos
Sema YILDIRIM July 1, 2021
can you please help me too? My problem is I have this "Change Type" field. When "deployment" is selected as a child option in this field, I want to bring automatic text to the description field.
Begoña Bonet
I've included this code in the script associated to "Es menor" customfield:
def parentOptionId = optionMap.getAt(0)
def longValue = Long.valueOf(parentOptionId).longValue()
log.debug("Parent option value : ${optionValue}")
if(getActionName() == "Create" && optionValue!="Proyectos"){
image2015-11-27 14:12:42.png
But it doesn't work:
image2015-11-27 14:11:51.png
Any idea in what am I doing wrong?
November 30, 2015
Hi Begona, Could you please attach the logs ?
November 30, 2015
I think I found the problem. You have to assign the script to the 'Area/Subarea' instead of the 'Es Menor'. You want to check the value of the cascading list and whenever this value is changing then hide or shown the Es Menor custom field. I also updated the above script to check for null values (if an option in the cascading list is not available) Please let me know if that does the trick. Regards Thanos
Begoña Bonet
Thanos It has worked fine for parent option! But I need the child option value. How can I get this value? Many thanks in advance!
November 30, 2015
Begona , I updated the script in order to return the child option
Begoña Bonet
It has worked perfectly. Many thanks Thanos!!
Begoña Bonet
One more question (sorry for my ignorance). Which is the difference between optionMap.getAt(0) and optionMap?.getAt(0) ?
December 1, 2015
It is called safe dereference operator. So in the above code if you use optionMap.getAt(0) and the oprionMap is null (in your case if getFieldByName("Área/Subárea").getValue() is null) then the above code will throw a java.lang.NullPointerException: Cannot invoke method getAt() on null object at Script1.run(Script1.groovy:9) The ? operator will cause the above call to fail in 'silent' (without null exceptions). I think is a big discussion and it depends on whether you want the exception to be thrown (and handled accordingly) or not. To be honest I am trying to adapt such kind of groovy's features in order to make the code more "laconic", cause I just want the code to be executed for valid references and just be silent otherwise. Hope my answer makes sense.
Begoña Bonet
Now I understand, many many thanks for your help
