Behaviour to make user populate 1 of 2 fields at least
Rob B
February 6, 2024
User has to populate 1 of 2 specific fields.
Can this also produce and error at the top to advise this?
PD Sheehan
February 6, 2024
Hi @Rob B
Yes, using a Behaviour server-side script, you can make 2 fields co-required. I.e. at least A or B must be populated.
Here is how you might do that.
1) In field A, add a server-side script
def fieldA = getFieldByName('A Name')
def fieldB = getFieldByName('B Name')
fieldB.setRequired(!fieldA.value)
2) in field B, add a server-side script
fieldA.setRequired(!fieldB.value)
What this does is tie whether 1 field is required on the value of the other. If there is a value in field A, field B is no longer required. But when field A is empty, then Field B is required.
And vice versa.
When both fields are empty, both fields will appear as required. But the second you populate one of them, the other will not be required anymore.
If the user attempts to submit while both are empty, they will both be flagged in red with "this field is required".
If you want, you can add this to both scripts if you want to be more explicit when both fields are empty:
if(!fieldB.value && !fieldB.value){
fieldA.setError('Either field A or field B must be filled in')
Rob B
February 7, 2024
Excellent! Thanks Pete!
Trudy Claspill
February 6, 2024 edited
Hello @Rob B
Are these fields that need to be populated at all points during the issue lifecycle? If so, you could simply set them as Required in the Field Configuration.
Are the fields that need to be filled in during a status transition? In that case you could add a Validator to the transition.
Why are you asking specifically for a Behavior solution?
You said 1 of 2 fields. Does that mean you want only  one or the other populated but not both? Is there some additional criteria to determine which should be populated?
SERVER
Register Now
