I am trying to write a Groovy Script in Behaviours Plugin.
I have two Database Custom Fields, "Header Priority Value" and "SubHeader Priority Value".
I get the values 3.000000 and 2.000000 for these fields (Using SQL Query).
I have to add the values in those two fields and get the sum, and use that sum to set Priority.
This is the script i put on "SubHeader Priority Value" field:
FormField GV = getFieldById ("priority")
FormField HP = getFieldByName ("Header Priority Value")
FormField SHP = getFieldByName ("SubHeader Priority Value")
String HPV = HP.getValue()
String SHPV = SHP.getValue()
String PVSUM = HPV + SHPV
log.error PVSUM
When i run this i am getting 3.0000002.000000 instead of 5.000000
I think this is because the values are considered as Strings. How do i do it ?
you're casting them to strings... try using
def HPV = HP.getValue()
etc
if that doesn't work try casting to longs:
def HPV = HP.getValue() as Long
If they could be null try this:
def HPV = HP.getFormValue() ?: 0 def SHPV = SHP.getFormValue() ?: 0 def PVSUM = HPV + SHPV
I tried 'def' but got an error. I will try to Cast it as Long and see if it works. Thank You.
I don't see how you can have got an error... paste the full minimal code and include the error.
Right now i have solved the problem by using only one field "SubHeader Priority Value" to determine the "Priority". But, i want to know how to add Numbers. So, This is the code i used: FormField GV = getFieldById ("priority") FormField HP = getFieldByName ("Header Priority Value") FormField SHP = getFieldByName ("SubHeader Priority Value") def HPV = HP.getValue() def SHPV = SHP.getValue() def PVSUM = HPV + SHPV log.error PVSUM And i got this: http-bio-8080-exec-13 ERROR uyadlapalli 801x8141x6 1bvbulw /rest/com.onresolve.jira.plugin.Behaviours/1.0/behaviours/runvalidator.json [onresolve.jira.behaviours.BehaviourManagerImpl] Script function failed on issue: (create issue) project/issuetype: TEST/Bug, user: uyadlapalli, fieldId: customfield_11703, file: <inline script> groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.util.json.JSONObject$Null.plus() is applicable for argument types: (com.atlassian.jira.util.json.JSONObject$Null) values: [null] Possible solutions: split(groovy.lang.Closure), is(java.lang.Object), use([Ljava.lang.Object;), wait(), grep(), find() at Script1.run(Script1.groovy:8)
looks like one or both is null, check my updated answer
Yes Jamie. They will be Null initially. Thank you. That Works.
