Sign up Log in
Behaviours Plugin - Prevent Default Warning Popup when Issue Type is changed
Christina Hiller
May 23, 2019 edited
I've implemented a behavior to set a default Description and mapped to one issue type within a project.  I've tried this by adding server side script to the field itself as well as in the initializer script (as shown in screenshot below)
Now, when a user attempts to Create an issue and starts off on the one mapped to a Behaviour to populate the description, to an issuetype that is not mapped, a pop-up notification is received.
Is there a way to disable this?
Screenshot of the Popup that I don't want.
Configuration
Baris Kuzu May 15, 2024
Hello Christina,
It looks like you have already predefined a text for the description field via the system fields.
This causes ScriptRunner Behaviors to conflict with the system.
Go to Jira Administration/Issues/System Fields then to the line of the "Description" field and click on the three dots and then on "Contexes and default values". There you will see that there are already predefined texts for the system field "Description".
The warning message from Script Runner only appears if a default value is already stored for the Description field in the same project or for the same issue type under the system fields.
I hope this has helped you.
Best regards,
Baris
atlassian, ace, atlassian community event, donation, girls who code, women in tech, malala fund, plan international, kudos, community badge, badge, atlassian badge, International Women’s month, International Women’s Day, women's month, women's day
10 for Change at Atlassian Community Events
Show up and give back by attending an Atlassian Community Event: we’ll donate $10 for every event attendee in March!
Join an Atlassian Community Event!
Upcoming Jira Events
