Hellow,
In a project, when issue created, if "Application" value equals to "Cleva Life v7", the "Functional Area" required.
The "Application" and "Functional Area", are custom fields Type "Select List (single choice)".
Exemple:
The problem, is that don't work very well.
Script:
import com.atlassian.jira.config.properties.APKeys
import com.atlassian.jira.datetime.DateTimeFormatter
import com.atlassian.jira.issue.customfields.impl.DateTimeCFType
import com.onresolve.jira.groovy.user.FieldBehaviours
import org.apache.log4j.Logger
import org.apache.log4j.Level
import groovy.transform.BaseScript
import groovy.transform.Field
@BaseScript FieldBehaviours fieldBehaviours
@field ApplicationUser loggedInUser = ComponentAccessor.jiraAuthenticationContext.loggedInUser
// Set the log level
def log = Logger.getLogger(getClass())
log.setLevel(Level.DEBUG)
// Related issue field name
final functionalAreaName = "Functional Area"
final applicationName = "Application"
//Issue picker field and its value is obtained
def issuPickerFieldFunctionalArea = getFieldByName(functionalAreaName)
def issuePickerFieldValueFunctionalArea = issuPickerFieldFunctionalArea.value
def issuPickerFieldApplicationName = getFieldByName(applicationName)
def issuePickerFieldValueApplicationName = issuPickerFieldApplicationName.value
// Application value equals to "Cleva Life v7" , Functional Area required
if (issuePickerFieldValueApplicationName == "Cleva Life v7") {
issuPickerFieldFunctionalArea.setRequired(true)
return
} else {
issuPickerFieldFunctionalArea.setRequired(false)
return
What is wrong?
Isabel Fonseca
I found a better solution, insert a validator in transition of issue:
Many thanks,
Isabel Fonseca
