Behaviours Script/script post function to set a insight custom field based on part of the summary
Florian Schüller
dear community,
i need your help to write a behaviour script or a custom script post-function which will set a insight custom field based on the first part of the summary when ticket is created.
The summary looks like "CI-52005 is disabled."
CI-52005 is the key from the insight field which will be set.
Does anyone have some ideas or similar requests?
best regards,
florian
Florian Schüller
hi @Gundlupet Sreenidhi
First i tried it with an insight field (but i think this will not work)
So i decided to create a new customfield (type string single line) but it didnt work.
Florian Schüller
today i tried it again with a normal string field. unfortunately it didnt work.
the custom script  post function is set in the workflow transition "create" after the function "create issue" (screenshot)
i dont know whats wrong.. hmhm
Gundlupet Sreenidhi
October 23, 2018
Try this.
Lets assume customfield_11111 is the ID for your customfield
if(getFieldById("summary").getValue().toString().startsWith("CI-52005")){
   getFieldById("customField_11111").setFormValue("CI-52005")
 The above code snippet works only for your example shown above.
If you would like to genaralise it for any summary ,first retrieve the substring from the summary you want to set, then set the value - shown below
String identifiedValue = getFieldById("summary").getValue().toString().subString(0, getFieldById("summary").getValue().toString().indexOf(" "))
getFieldById("customfield_11111").setFormValue(identifiedValue)
What I am doing here is getting the substring from the summary - from position 0 (start of string) till the space is encounters (i.e: the first word. Then assigning it to the form value of your custom field.
Hope this helps.
Florian Schüller
Thanks a lot!
unfortunately i got an error after the first ticket was created.
I created a custom script post function on the workflow transition "create" with your script.
Then i tried to create a ticket but this error message returned:
Time (on server): Tue Oct 23 2018 14:22:19 GMT+0200 (Mitteleuropäische Sommerzeit)
The following log information was produced by this execution. Use statements like:log.info("...") to record logging information.
2018-10-23 14:22:19,853 ERROR [workflow.ScriptWorkflowFunction]: *************************************************************************************
2018-10-23 14:22:19,855 ERROR [workflow.ScriptWorkflowFunction]: Script function failed on issue: LC-187, actionId: 1, file: <inline script>
groovy.lang.MissingMethodException: No signature of method: org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.getFieldById() is applicable for argument types: (java.lang.String) values: [summary]
 at Script136.run(Script136.groovy:1)
Something i forgot to do?
Gundlupet Sreenidhi
October 23, 2018
What I provided is a behavior script - not a post-function.
getFieldById("summary") should work on a behavior. Can you validate?
Gundlupet Sreenidhi
October 23, 2018
If you would like it to be part of the post-function, try this:
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.CustomFieldManager
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
CustomField setValueField= customFieldManager.getCustomFieldObject("customfield_11111")
String setValueFieldVal = issue.getCustomFieldValue(setValueField) as String
log.info "current Field Value :"+setValueFieldVal
String summary = issue.getSummary()
String identifiedValFromSummary = summary.substring(0,summary.indexOf(" "))
issue.setCustomFieldValue(setValueField, identifiedValFromSummary);
Florian Schüller
This Script is running, but the field wasnt set. The custom field is an insight field. I also tried it with a normal jira custom field.
Do you have some ideas why the value wasnt set?
Gundlupet Sreenidhi
October 23, 2018
Can you explain a little of what is an insight field? This is not part of JIRA (nor any plug-in I have worked with).
Is it something provided by some other plug-in?
Try to implement logging to see where it is going wrong.
I have update the same post-function snipped above with logging:
import org.apache.log4j.Category
log.info "Summary: "+summary
log.info "identifiedValFromSummary : "+ identifiedValFromSummary
Once you have the logger in place, you should be able to see the logs in the post-function.
(After you perform the action / transition, open the postfunction in edit mode to see the log)
Click on any of the status (shows only latest 15 logs) to see the details:
Florian Schüller
thanks for the log.
i have updated the script and created a ticket. the custom field wasnt set.
Then i showed the execution informations about the logs.
there were no logs found.
Insight custom Fields:
Fields which are connected to the addon Insight (Riada)
But its also ok if i could set the value in a normal custom field.
Gundlupet Sreenidhi
October 23, 2018
Did you initialize the logging functionality for your script?
Can you show what you have in your script?
Florian Schüller
hi!
sorry for the circumstances, but i am really new into that. Thank u for your help!
CustomField setValueField= customFieldManager.getCustomFieldObject("customfield_11009")
Gundlupet Sreenidhi
October 24, 2018
Hi @Florian Schüller
Do you know what type of field the insight field is ?
Your code looks similar to mine.
The one reason I guess it may not be working is if the type is a mismatch.
What I have does so far is to try and set a String value to a custom field(assuming it accepts Strings). If that is not the case, then we need to set the exact type of value to our custom field.
Do you by chance know what type it is?
One way to find out: go to Administration --> Issues --> Custom Fields
Search for the Insight field and send see the type.
Example:
