Behaviours: Write an hardcoded description
Dan27
I write a behaviour that set default description data while creating "Bug-Internal" and "Sub-Bug" types (By Map).
It worked ok, But also all other types set this description..
How can I clear this in other types? I try with a condition but it still worked on all types.
this is my code:
def desc = getFieldById("description")
//def issueType = getFieldById("issuetype")
def defaultValue = """h3. General OS / DB / Browser / Machine Information:
h3. Scenario Description and steps to recreate the problem:
h3. Actual & Expected Results
h3. Log file information:
h3. Additional info (Optional):
if ((issueContext.issueType.name !="Bug-Internal") && (issueContext.issueType.name !="Sub-Bug")){
desc.setFormValue("")
else {
desc.setFormValue(defaultValue)
Mark Markov
June 20, 2018
Hello @Dan27
Where are you place your code? I check it and it works pretty well.
You need to map it to issuetype field
Dan27
hi @Mark Markov
Where did you write this line ??
I write my code inside 'fields' in the Behaviours
Mark Markov
June 20, 2018
Here example for last version of scriptrunnerСнимок экрана 2018-06-20 в 17.10.30.png
Dan27
Unfortunately, My Behaviours looks different..
I wrote my code inside Filters, and I chose Bug-Internal and Sub-Bug in Map.
Mark Markov
June 21, 2018
Can your provide screenshot of your configuration?
You need to create behaviour like this
1) Add-ons -> Behaviours -> Add
2) Add mapping to your project and all issue types
3) Fields -> Add "Issue Type" field
4) On added field add serverside script and place your code here
Marcos Sanchez
June 20, 2018
Hi Daniel,
As I understand, you are setting the behaviour with a mapping that affects only Bug-Internal and Sub-Bug issuetypes and then, inside your code, you are setting the description field based on the issuetype (again).
That's the problem, let me explain myself:
As far as you set the mapping for only Bug-Internal and Sub-Bug, when you choose one of these issuetypes the field will be set correctly because it triggers the behaviour, but when you change to another issuetype they will not use the behaviour as you didn't set them on the mapping.
So, this part of the code if ((issueContext.issueType.name !="Bug-Internal") && (issueContext.issueType.name !="Sub-Bug")) is redundant with the mapping and will not be used when you choose a different issuetype.
I'm not sure of which is the very best way to do this, but if you don't specify the issuetype on the mapping (only specify the project(s)) it should work with your current code.
Hope it helps.
Marcos
Dan27
@Marcos Sanchez I didn't understand.. Remove the Map (Choose all types) and leave the condition inside the code ?
Marcos Sanchez
June 20, 2018
Yes, choose all types (but defining the project, of course).
As I said, maybe there could be better ways to do this, but I'm not sure of which ways are...
Marcos
Dan27
it's still not working...
