Behaviours script broken after upgrade and update
Lacey Also June 1, 2015
Upgraded JIRA server instance from 5.0.4 to 5.1 this Sunday (yesterday). Mandatory update of Groovy (thereafter renamed Script Runner) to 2.1.15
Behaviours has script to select JIRA component relative to two custom field options. This script is no longer working, except for the error message line at bottom. The field on our issue info tab is no longer being populated at all, let alone as dependent upon the two custom fields.
Are the two plugins now fighting? Or is it due to the upgrade to 5.1?
I can't seem to get a straight answer from anywhere or anyone. Atlassian just directed me to Jaime, and I have no idea if that's even the problem here. This is a show-stopping issue, so I really need answers.
Advised via https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner#support Adaptavist runs Script Runner, and to submit support REQ through here.
JamieA
June 1, 2015
Behaviours wasn't merged into Script Runner until 3.0, so you will still need both, as you are on a very old version of jira. If you use the latest compatible version of both you should be fine.
@Jamie Echlin (Adaptavist) Reference https://jamieechlin.atlassian.net/browse/GRV-728 as well as original issue https://support.atlassian.com/servicedesk/customer/portal/22/JSP-233741 It definitely is not fine, unfortunately... We have ScriptRunner 2.1.15 and Behaviours 0.5.3 The dropdowns are not tying to the Components field as specified within the previously operational script. Same with the behavior of the Root SR field script. See GRV-728 please!
JamieA
June 1, 2015
Did Atlassian not tell you that jira 5.1 is out of support? Are there any errors in your log file?
JamieA
June 1, 2015
I don't understand why you upgraded to such an old version... it's extremely hard to imagine what might be the problem with a version that's 2.5 years old. But please have a look what's in your log file.
@Jamie Echlin (Adaptavist) They did mention that JIRA 5.1 is EOL. I will pull the log file as indicated... We upgraded to an old version from 5.0.4 due to having integration with NetSuite. I was under the impression that older versions of JIRA would not be able to have this integration with NetSuite.
Lacey Also June 2, 2015
I have the log file - would you like me to attach it to the GRV issue?
Learn more
