Hopefully my subject line says it all: What is the best way to import from MKS Integrity Manager to Jira? From my perusing of the Importer plugin, I will probably need a two step approach a and use CSV as the interim step. I'm hoping it is simplier than that.
Thanks, Brent
Looks like CSV only.
I've not even heard of MKS Integrity Manager before. It is very likely that the CSV option is your best bet, but we can't be totally sure of that without knowing a little more about the structure of the data you can get out of it.
