Thats the question how to get two cascade fields working in two directions?
putting value in field A, you have options in B
putting value in field B you have values on A.
Thanks.
You'd need to write a new custom field type to be able to do that. The logical structure of the internal cascading select is parent/child, not free-form.
You might be able to do it with two standard select lists though, linked by Behaviours from the Script Runner add-on
I think actual script-runner plugin does not provide "JS Behaviours"
I just see groovy code like fields,functions,conditions...
Nope, that's wrong, Behaviours became part of it over a year ago.
Unless you're on a quite old version, Behaviours is in the Script Runner.
