×Hi
We have a custom country field which is set to be required, and is popuplated with allowed values from a table lookup. We are using the database-values plugin for this.
However, bonfire is not displaying this field, and because it is set to be required, nobody is able to create issues through bonfire.
Is there a way to get the custom field displayed (and populated), or, is there a way for bonfire to show the 'real' create issue page when the issue failed to create the first time?
Hi Andy,
Thanks for trying out Bonfire.
You raise an interesting question for us here about pluginized custom fields. It is currently not supported by Bonfire, so unfortunately, I do not think there's an immediate workaround apart from making the field not "required" in JIRA, or using a JIRA out-of-the-box custom field type.
In the longer term, we may consider having some support for this. We've updated the issue on our isse tracker as well at: https://jira.atlassian.com/browse/BON-173
Edwin
