×I added projects using db scripts. Among the main tables were project_key, projectversion, nodeassociation and did a full re-indexing of JIRA instance. But when I browse for projects by http://localhost/secure/BrowseProjects.jspa, throws an exception "
"hasDefaultAvatar", exception: java.lang.NullPointerException
at com.atlassian.jira.web.action.browser.BrowseProjects$ProjectCategoryBean$1$1.hasDefaultAvatar(BrowseProjects.java:332)
Unable to understand this exception. What could have gone wrong?
Krishnan
Looks like you do not have an avatar set up? You might have to programmatically set that when creating the project using API.
Regarding the project import conversation, an easy approach is to transfer the AO data and configurations using scripts and rely on project import for everything else. We, Go2Group, has successfully done that for many customers.
Thanks Jobin, I got into the logs and found " /secure/BrowseProjects.jspa [webwork.util.ValueStack] METHOD: "hasDefaultAvatar", exception: ". Found there is mismatch between the avatar in project and the owner of avatartype in Avatar. I am just fixing that. Initially I started off like you suggested but when I couldn't go beyond this exception "Unable to import custom field 'Sprint'. The custom field type does not support project imports.", I started writing db scripts.
This is almost certainly the entire problem. Your scripts have missed something. I would very strongly recommend that you immediately revert to the backup you took before you ran your scripts. Then do your project creation properly, not with SQL.
Export and project import. Never SQL
Moreover, during the project import the following exception is thrown. "Unable to import custom field 'Sprint'. The custom field type does not support project imports."
