×Following layout on my page:
Info-block
UI Expand inside
Info-block inside
UI Expand inside
draw.io embedded diagram
If I select page 2 within the draw.io embedded diagram macro the preview is fine. If I enlarge the picture by clicking on it always the picture of page 1 is displayed.
Does anyone know a workaround.
Unfortunately, we don't currently support the Refined expand macro, only the Atlassian expand macro. If you are not using Refined UI Expand macro, please submit all the details to https://drawio.atlassian.net/servicedesk/customer/portal/14/group/15/create/49
To get started, we need drawio version, server version, your drawio SEN, storage format of the page and diagram file if possible.
Also, check if you see the same behaviour in other browsers and Incognito mode.
Marija
I use the Refined UI Expand macro.
Thanks for the reply.
No I know that have to rearrange the site a bit.
