When importing from Bugzilla using the JIRA Importers Plugin version 5.0.4, disabled user are imported into a group called bugzilla-import-disabled-users, but the accounts are still marked Active. In some cases they are also added to some default groups like jira-developers and jira-users. Is there a solution for this problem?
We're using Atlassian JIRA (v5.2.4.1#846-sha1:7ae4d02)
try this to select all cwd_membership entries and then delete them(did this on JIRA 5.0.4, it's safe, but test it before). Also you should restart JIRA and reindex(don't remeber if there is need in reindex).
select * from cwd_membership cwm inner join cwd_user cwu on cwm.child_id = cwu.id where cwu.id in (select cwu1.id from cwd_membership cwm1 inner join cwd_user cwu1 on cwm1.child_id = cwu1.id and cwm1.parent_name in ('bugzilla-import-disabled-users', 'bugzilla-import-unused-users'))
JIRA counts licence user limit using jira-users group - so it's a workaround
