I am getting the following message error when trying to load the helloworld plugin into Jira:
[INFO] Scanning for projects...
[INFO] ------------------------------------------------------------------------
[INFO] Building helloworld
[INFO] task-segment: [com.atlassian.maven.plugins:maven-amps-dispatcher-plugin:4.1.6:run]
[INFO] Preparing amps-dispatcher:run
[ERROR] BUILD ERROR
[INFO] The plugin 'com.atlassian.maven.plugins:maven-amps-plugin' does not exist or no valid version could be found
[INFO] Trace
org.apache.maven.lifecycle.LifecycleExecutionException: The plugin 'com.atlassian.maven.plugins:maven-amps-plugin' does not exist or no valid version could be found
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.verifyPlugin(DefaultLifecycleExecutor.java:1546)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.getMojoDescriptor(DefaultLifecycleExecutor.java:1786)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.bindLifecycleForPackaging(DefaultLifecycleExecutor.java:1274)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.constructLifecycleMappings(DefaultLifecycleExecutor.java:1238)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.forkProjectLifecycle(DefaultLifecycleExecutor.java:1031)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.forkLifecycle(DefaultLifecycleExecutor.java:1009)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:627)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeStandaloneGoal(DefaultLifecycleExecutor.java:553)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(DefaultLifecycleExecutor.java:523)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHandleFailures(DefaultLifecycleExecutor.java:371)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegments(DefaultLifecycleExecutor.java:332)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLifecycleExecutor.java:181)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:356)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:137)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:356)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.plugin.version.PluginVersionNotFoundException: The plugin 'com.atlassian.maven.plugins:maven-amps-plugin' does not exist or no valid version could be found
at org.apache.maven.plugin.version.DefaultPluginVersionManager.resolvePluginVersion(DefaultPluginVersionManager.java:229)
at org.apache.maven.plugin.version.DefaultPluginVersionManager.resolvePluginVersion(DefaultPluginVersionManager.java:91)
at org.apache.maven.plugin.DefaultPluginManager.verifyPlugin(DefaultPluginManager.java:172)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.verifyPlugin(DefaultLifecycleExecutor.java:1517)
... 22 more
[INFO] Total time: < 1 second
[INFO] Finished at: Thu Apr 18 11:15:54 BRT 2013
[INFO] Final Memory: 7M/18M
I am using Maven and the settings.xml is configured as shown below. I don't have a clue on what else to do.
Regardind localrepository:
<localRepository>c:/users/dearaujo/atlassian-plugin-sdk/repository/</localRepository>
Regarding m2-proxy repositories:
<repository>
<id>atlassian-public</id>
<url>https://m2proxy.atlassian.com/repository/public</url>
<snapshots>
<enabled>true</enabled>
<updatePolicy>never</updatePolicy>
<checksumPolicy>warn</checksumPolicy>
</snapshots>
<releases>
</releases>
</repository>
<repository>
Maybe it's a problem with the proxy. You could try the solution in this question:
https://answers.atlassian.com/questions/20079/plugin-sdk-does-not-use-http-proxy
Are you using Maven, or the packaged atlas-mvn (or did youalter the path to the settings.xml?). I have seen similar errors when using my default maven install which does not include the Atlassian M2-Proxy repositories. YOU would see download warnings above the snippet you shared if this is the case.
<repository>
<snapshots>
</snapshots>
<releases>
</releases>
</repository>
<repository>
