Build error: unable to execute mojo while using atlas-run command
vimala nunavath June 5, 2012
I am trying to create a jira report plugin.To get the report I am following the given link (https://developer.atlassian.com/display/DOCS/Explore+the+Installed+SDK+and+the+atlas+Commands).
Could any one help me to solve the following mentioned error:
[INFO] [cargo:start]
[INFO] [stalledLocalDeployer] Deploying [C:\Atlassian\atlassian-plugin-sdk-3.10.
4\bin\atlassian-tutorial\amps-standalone\target\jira\jira.war] to [C:\Atlassian\
atlassian-plugin-sdk-3.10.4\bin\atlassian-tutorial\amps-standalone\target\contai
ner\tomcat6x\cargo-jira-home/webapps]...
[INFO] [talledLocalContainer] Tomcat 6.x starting...
[INFO] ------------------------------------------------------------------------
[ERROR] BUILD ERROR
[INFO] Unable to execute mojo
Deployable [http://localhost:2990/cargocpc/index.html] failed to finish deployin
g within the timeout period [180000]. The Deployable state is thus unknown.
[INFO] For more information, run Maven with the -e switch
[INFO] Total time: 6 minutes 36 seconds
[INFO] Finished at: Wed Jun 06 10:12:49 CEST 2012
[INFO] Final Memory: 40M/310M
[WARNING] [talledLocalContainer] Java Result: 1
Help would be appreciated!
Thanks in advance!!
Vimala
Jouni Airaksinen
November 8, 2012
I had the same problem on OS X. Turned out to be issue with FileVault in the home directory which caused everything take very long. After moving the project outside the home directory, all went very fast with no issues.
Register here ⬇️
