Bulk User Deactivation in Jira
ashleyg
I recently got an update from Atlassian which says that using the below query bulk user deactivation is possible in Jira.
update cwd_user u set active = 0 WHERE u.id in ("a1234","b1234","c1234",.........)
I would just like to confirm if this query can be directly used to bulk update the users for purpose of deactivation because we have the actual username list and would just like them all to be deactivated.
I have around 1000 users to be deactivated in an excel sheet and I hope using excel formula if I enclose all such 1000 usernames within double quotes and create comma separated list and directly place them in update query as above then that should work.
Please let me know if this correct or if not then what else needs to be done.
Ashley
Benito Picarelli
May 21, 2015
Hi Ashley,
Yes, that query should work to bulk disable those users.
ashleyg
Hi Benito, Thanks for the quick response. I would just like to know one more thing. Do I need to enclose usernames in double quotes? Is everything I mentioned as part of update query (I mean all parameters) correct? Thanks, Ashley
