Bulk add label to filtered issues
Alexey Paveliev
January 31, 2013
Is there a workaround to https://jira.atlassian.com/browse/JRA-24118 ? BTW Please vote!
I need to add a label to some issues based on issue navigator search result. Bulk edit erases old labels and adds new which does not work for me.
Is there coding-free option?
15 votes
Henning Tietgens
January 31, 2013 edited
Get Script Runner plugin and execute following Groovy script:
import com.atlassian.jira.web.bean.PagerFilter
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.label.LabelManager
import com.atlassian.jira.bc.JiraServiceContextImpl
filterId = 10000
labelName = 'Label'
cm = ComponentManager.instance
labelManager = ComponentManager.getComponentInstanceOfType(LabelManager.class)
searchRequestService = cm.searchRequestService
searchProvider = cm.searchProvider
user = cm.jiraAuthenticationContext.getLoggedInUser()
ctx = new JiraServiceContextImpl(user)
sr = searchRequestService.getFilter(ctx, filterId)
searchResult = searchProvider.search(sr?.getQuery(), user, PagerFilter.unlimitedFilter)
searchResult.issues.each{issue ->
    labelManager.addLabel(user, issue.id, labelName, false)
"Done."
Adapt filterId and labelName to your needs.
Henning
Sorin Sbarnea (Citrix)
August 28, 2013
Is this going to send any email notifcations or not? I will it will not send them.
Henning Tietgens
August 28, 2013
It depends on the last parameter for addLabel(). If it's false like here, no notifications are send. If it's true, notifications are send.
August 28, 2013
Thank you. Due to the nature of the problem we decided to implement a SMTP filter for changes made by a service account jira user.
Jacob Gilley
December 18, 2014
Thanks for the script, Mr Tietgens!
Tej
This is actually cool thank you Tietgens!
How to convert the script rather than using filter id by using JQL search in the script?
Tej
Henning Tietgens
February 3, 2018
I updated the script from my old answer, there was some html code from the conversion from Atlassian Answers to Community.
Here is a solution using JQL search:
def jqlSearch = "project = ABC"
def labelName = 'Label'
def labelManager = ComponentAccessor.getComponent(LabelManager)
def user = ComponentAccessor.jiraAuthenticationContext.getLoggedInUser()
def searchService = ComponentAccessor.getComponent(SearchService)
if (user) {
def parseResult = searchService.parseQuery(user, jqlSearch)
if (parseResult.isValid()) {
def searchResult = searchService.search(user, parseResult.getQuery(), PagerFilter.getUnlimitedFilter())
} else {
return "Invalid JQL $jqlSearch"
} else {
Return "No logged in user found!"
"Done."
 It's typed without without verification, so test first on a staging environment :-)
Henning
Tej
Henning thanks alot for help
when I tried old script by using filter id adding label, it throwing an import error
Henning Tietgens
February 4, 2018
Yes, ComponentManager shouldn't be used anymore. Try the new script or try to replace ComponentManager by ComponentAccessor like in the new script.
T February 5, 2018
I replaced ComponentManager by ComponentAccessor, but still
Error
startup failed: Script273.groovy: 2: unable to resolve class com.atlassian.jira.ComponentAccessor @ line 2, column 1. import com.atlassian.jira.ComponentAccessor ^ 1 error
when I used JQL  2nd script its
Error
startup failed: Script275.groovy: 23: unexpected token: No logged in user found! @ line 23, column 9. Return "No logged in user found!" ^ 1 error
Henning Tietgens
February 6, 2018
Ok, some typing errors and a missing import in the JQL script, here the updated version:
import com.atlassian.jira.bc.issue.search.SearchService
if (user) {
} else {
} else {
return "No logged in user found!"
"Done."
Henning Tietgens
February 6, 2018
And here the filter id script for current Jira versions:
import com.atlassian.jira.bc.filter.SearchRequestService
import com.atlassian.jira.issue.search.SearchProvider
def filterId = 10000
def searchRequestService = ComponentAccessor.getComponent(SearchRequestService)
def searchProvider = ComponentAccessor.getComponent(SearchProvider)
def ctx = new JiraServiceContextImpl(user)
def sr = searchRequestService.getFilter(ctx, filterId)
def searchResult = searchProvider.search(sr?.getQuery(), user, PagerFilter.unlimitedFilter)
"Done."
Henning
Like • Azfar Masut likes this
Tej
Henning thanks a lot for your help, appreciate your work (y)
Awesome guy!
Azfar Masut
December 3, 2019
Love you @Henning Tietgens !
rithwik_poleneni February 21, 2020
@Henning Tietgens
does this code work for python 3 ?
Henning Tietgens
February 23, 2020
No, this is Groovy not Python.
Greg Reeve
October 17, 2013
@Henning Thanks for your example. I used it and modified to create a script to remove a single label.
Wanted to post it in case anyone else is looking to bulk rename labels. I'd suggest add new label then remove old.
filterId = 10602
labelName = 'Label'
    labelManager.setLabels(user, issue.id, (labelManager.getLabels(issue.id).collect{l -> l.getLabel()}.minus(labelName)) as Set, false, true)
"Label" + labelName + " removed from issues in filter " + filterId.toString()
