Bulk change Security Level
Jennifer D. Smith May 3, 2022
I need to set Security Level for over 100,000 issues. Bulk change 1000 at a time or Jira Automation constantly timing out are both terrible. It seems like I ought to be able to run larger batches via Jira CLI, but I can't get it to recognize the Security Level field by name or id (security).
Some commands I've tried (also variations with and without single and double quotes):
acli --action runFromIssueList --jql "project = CAPS AND 'Localization Help' is EMPTY" --common "--action setFieldValue --issue @issue@ --field security --value 10602"
acli --action runFromIssueList --jql "project = CAPS AND 'Localization Help' is EMPTY" --common "--action setFieldValue --issue @issue@ --field 'Security Level' --value Internal"
 I always get an error that the custom field "is not defined or not valid in this context." I think this might be because I'm on Jira 8.22 and Security Level is a system field? Anyone know how to get this to work?
2 accepted
Nic Brough -Adaptavist-
May 3, 2022
I have not checked this recently, but I wanted to get you an answer as fast as possible!
Last time I tried to set the Security level over REST, the field name/id was "level", not security or security-level - could you give that a quick shot?
The other thing to look at is if the account posting the security level is a part of it - only users in a level can apply it to an issue.
Hannes Obweger - JXL for Jira
Hi @Jennifer D. Smith @Nic Brough -Adaptavist-
I just had a look at our REST calls and I believe the field name is indeed security. However, the value is passed as "{ "id": "<id-value>" }, see below:
Screen Shot 2022-05-04 at 2.15.21 pm.pngPerhaps that is needed in the CLI, too?
Like Jennifer D. Smith likes this
May 4, 2022
Thanks for looking that up for us!
The id would make sense - the REST call expects the id of the security level, not the name!
Jennifer D. Smith May 10, 2022
Thanks to some hints I got from the API info from Nick and Hannes, this is the working Jira CLI call:
acli --action runFromIssueList --jql "project = CAPS AND 'Localization Help' is EMPTY" --common "--action setFieldValue --issue @issue@ --field security --value Internal --suppressNotify" --continue
Important: make sure that your CLI user's permissions are correct and also that the field is on the edit screen for the issue types that you are looking to change.
