Bulk change doesn't work between two projects
Fabio Manzoni
March 26, 2018 edited
Hi everyone,
I need to do issue bulk change betwenn two different projects. But when I start to do this change some request fields look messy or doesn't appers.
The first project uses a, b and c requested fields and I'm going to do a bulk change to another project with x,y and z requested fields. But this x,y and z fields somethimes doesn't appear during the bulk change.
Anyone have any idea what it could be?
Fabio Manzoni
Further information identifies that the problem occurs when you make the move, the fields that are not listed correctly are of type Dynamic Forms
The prints its the problem during the move.
Example:
In the first print can see "Mover incidencia:Actuializa campos" - Issue move and update fields.The first combo box our customer choose the item "Ninguno", but there aren't the field name, the same occurs in the 2nd and 4th field.
The 3th field appers correctly the name "Catalogo de Servicios".
The second print is the move in same situation, but just the 3th and 4th fields name appears correctly.In the 3th and 4th prints you can see the screen "Crear Incidencia" - Create issue - and 3 fields with their names.
I open a ticket at https://intenso.atlassian.net/servicedesk/customer/portal/1/SUPPORT-21893 and receive this answer.
"Thank you for your detailed response - I have managed to reproduce this problem and it has been passed to our developers.
I will keep you informed if this fix is available on our Marketplace.
I really sorry for the inconvenience and thank you for your help once again!"
Nic Brough -Adaptavist-
March 26, 2018
What do you mean "bulk change between two different projects"?
Fabio Manzoni
Nic,
It's a simple issue bulk change, but 2 different projects each one with own (work flow, fields etc)
March 26, 2018
So not between two projects, but involving issues from different projects.
When you try to edit issues from many projects (or even of different types), Jira can only work with fields that are available to all the issues you are trying to edit.
Fabio Manzoni
Nic,
See the images below, the fields appear to be filled, but the field names do not appear..
March 27, 2018
That looks right to me.  I can see field names, and their selections.  One cascading, two select lists.
Fabio Manzoni
In fact some fields do not present the description, the name of the field, only the space to fill the data. In this second image, note that it is the same screen and the presentation of the fields are different. Is that correct?
March 28, 2018
Again, I can't see a problem - I see field names and selects.  The placement looks wrong though.
Do you have Behaviours, 3rd party custom fields, or any javascript tricks in play?
