Bulk change "Resolution" field
Sri Ranjan July 23, 2013
is there a way to perform bulk change on the "Resolution" field in Jira 5.2?
4 votes
Austin Boyd [Equip]
I know this one is really old, but I just came up with a workaround since this is still not possible in 6.3.x and possibly later. Assuming that all issues in query are in the "Closed" status:
  1. Create a screen with the Resolution Field
  2. Modify the workflow(s) that are being used to include a transition loop to the same Closed status
  3. Add the newly created Resolution Screen to the transition
  4. Use the Transition Issues Bulk Change function
  5. The function will expose all fields that are on the transition screen (Resolution, Comment)
  6. Add the desired resolutions
  7. Back out changes to the workflow
You may need to make adjustments to this depending on how many statuses and workflows are involved.
Lionel MORAUX
December 22, 2015
Tested succesfully on JIRA 7.0.0. Thank you !
manalgamal November 19, 2019
It worked perfectly !! Thank you so much
Yves Martin
September 15, 2020
Ian
Yup. The workflow loop works perfectly. Just allowed "Allow all statuses to transition into..." my "Done" status and could transition issues with updating the resolution.
3 votes
Christian Czaia [Decadis AG]
July 23, 2013
You can use the script runner plugin which has a built-in script to bulk change resolutions:
https://jamieechlin.atlassian.net/wiki/display/GRV/Built-In+Scripts
Cheers Christian
Mert Karadağlı _ Köstebek Teknoloji _
We have released Bulk Operation Enhancer For Jira plug-in in marketplace.
https://marketplace.atlassian.com/plugins/com.kostebekteknoloji.plugins.jira.jira-bulk-operation-exhancer
You could do bulk operations like additive adding, replacing and removing labels.
You could also set Resolution field with Bulk Operations.
Documentation is here: http://www.confluence.kostebekteknoloji.com/display/PLUG/Bulk+Operation+Enhancer++for+JIRA
You can also contact with info@kostebekteknoloji.com for your new bulk operation suggestions
Yves Martin
September 15, 2020
This plugin does the job, when you need to fix current Resolution field value.
But if issue resolution is empty, bulk set Resolution action forgets to set technical "resolution date" which has impact on reports (standard, from apps or custom...)
Jobin Kuruvilla [Adaptavist]
July 23, 2013
Is it there on the screen for all selected issues?
Atlassian Guru
for individual issue yes, but on bulk screen there is no Resolution field.
Where could be gone :)
RambanamP
July 23, 2013
another way, check the following document to bulk edit resolutions
https://confluence.atlassian.com/display/JIRAKB/HowTo%3A+Bulk+Edit+Resolution
some one already raised an issue with atlassian
https://jira.atlassian.com/browse/JRA-7302
July 23, 2013
You can do this but only if you add the resolution field on to the screen. Add the field to "Edit" screen, bulk "Edit" to change the value and then remove it from screen to avoid people making changes accidently.
We do have "Resolution" field on the Edit Screen but its not showing up for bulk edit
Michael Voronkov October 20, 2014
Correct - adding Resolution to issue Edit Screen does not solve the problem, bulk edit still doesn't exposes it. But I can edit Resolution on individual issues.
Get Certified! ✍️
