Burn down chart to return remaining estimate and remaining value graph to converge to zero
Work Admin May 8, 2024
I am currently working with a customer that uses burndown chart to monitor their sprint and want this business requirement to be met at the close on issue
1. The chart should have the remaining estimate with a close action(post function) in place to return zero(0) for remaining estimate when an issue is closed
2. And the end of the sprint or when all the issues are close. the line  for remaining values to converge to zero
Tried a solution with a graph, close to what the customer wants but the remaining  displayed zero, when the issue is closed.
Danut M _StonikByte_
Hi @Work Admin,
Try the Sprint Burndown Burnup Chart gadget offered by our Great Gadgets app.
When configured to calculate  by Time Remaining & Time Spent, the gadget considers an issue with remaining zero if it is done, event if its remaining estimate field is not zero. So it might do the trick for you. The gadget can also count the sub-tasks.
Same for Velocity gadget and Release Burndown Burnup Chart gadget.
See also these articles:
You could start with the 1-month of free trial. If you have any questions, feel free to contact us at support@stonikbyte.com.
Hope this helps.
Danut
