Burnup chart for JIRA Server 7.4 ?
Matt Stephens
Hi Community!
I've just started working with a company that has JIRA Server 7.4 installed.  There doesn't appear to be any Burnup chart capability in that version, so I'm looking at options.  Can anyone recommend best options?  A plug in?  Or other approach?
Matt
Manon Soubies-Camy
Hello Matt,
Do you know if you're on Jira Core or Jira Software? You need Jira Software to get this kind of report.
Hope this helps,
- Manon
Matt Stephens
Thanks @Manon Soubies-Camy, I think we are on Jira Software as I do have access to those reports yes.  However, none of those reports is a burnup chart.  I want to be able to see a burnup chart at different timeboxes - sprint, release, overall project, etc.
I'm really looking for a nice simple visual chart that shows stories added to sprint (or whatever) backlog over time, compared with what's been completed in that timebox.
https://marketplace.atlassian.com/plugins/com.clariostechnology.intelligentreports/server/overview seems like a decent option, but looks more focussed towards putting these into a report.  I'd rather have something more dynamic like the normal JIRA 'reports'.
Manon Soubies-Camy
I've just seen there is a feature request about Burnup chart in Jira Server, you can watch it to be updated.
Intelligent Reports isn't Atlassian verified so I'd rather suggest using eazyBI or Arsenale Dataplane.
- Manon
Matt Stephens
Ah thanks, will have a look at those.
Ilze Leite-Apine - eazyBI
indeed, you can create burn-ups and burn-downs in eazyBI. There are some examples in eazyBI demo account to check out, for instance:
Sprint story point burndown
Story points burn down in selected epic
Version burn down with issues
For more detailed assistance with them, do not hesitate to contact eazyBI support
Ilze,
eazyBI Customer Support
Matt Stephens
Hi @Ilze Leite-Apine - eazyBI, thanks for the info.  However, none of those is quite what I'm really looking for.  What I want to do is clearly (and simply visually) show the impact of new items being added to the backlog (either in a specific sprint, or across a release or the whole project), or indeed work being removed (as opposed to getting completed).  Generally, people look to a Burn UP chart to achieve this, but I guess it can be shown in other ways.
A nice simple explanation is here: http://www.clariostechnology.com/productivity/blog/whatisaburnupchart - the first chart demonstrates both scope increase and decrease perfectly...
